Ahead of Time Static Analysis for Automatic Generation of Debugging Interfaces to the Linux Kernel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automated Software Engineering Année : 2014
The Linux kernel does not export a stable, well-defined kernel interface, complicating the development of kernel-level services, such as device drivers and file systems. While there does exist a set of functions that are exported to external modules, this set of functions frequently changes, and the functions have implicit, ill-documented preconditions. No specific debugging support is provided. We present Diagnosys, an approach to automatically constructing a debugging interface for the Linux kernel. First, a designated kernel maintainer uses Diagnosys to identify constraints on the use of the exported functions. Based on this information, developers of kernel services can then use Diagnosys to generate a debugging interface specialized to their code. When a service including this interface is tested, it records information about potential problems. This information is preserved following a kernel crash or hang. Our experiments show that the generated debugging interface provides useful log information and incurs a low performance penalty.
paper.pdf (419.29 Ko) Télécharger le fichier
hal-00992283 , version 1 (21-05-2014)
Tegawendé F. Bissyandé, Laurent Réveillère, Julia Lawall, Gilles Muller. Ahead of Time Static Analysis for Automatic Generation of Debugging Interfaces to the Linux Kernel. Automated Software Engineering, 2014, pp.1-39. ⟨10.1007/s10515-014-0152-4⟩. ⟨hal-00992283⟩
483 Consultations
447 Téléchargements
