Calibration of Scanning Electron Microscope using a multi-images non-linear minimization process. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a novel approach of SEM calibration based on non-linear minimization process is presented. The SEM calibration for the intrinsic parameters are achieved by an iterative non-linear optimization algorithm which minimize the registration error between the current estimated position of the pattern and its observed position. The calibration can be achieved by one image and multiple images of calibration pat- tern. Perspective and parallel projection models are addressed in this approach. The experimental results show the efficiency and accuracy of the proposed method.
ICRA14_0626_FI.pdf (235.45 Ko) Télécharger le fichier
hal-00992614 , version 1 (19-05-2014)
  • HAL Id : hal-00992614 , version 1
Le Cui, Eric Marchand. Calibration of Scanning Electron Microscope using a multi-images non-linear minimization process.. IEEE Int. Conf. on Robotics and Automation, ICRA'14, Jul 2014, Hong-Kong, Hong Kong SAR China. ⟨hal-00992614⟩
204 Consultations
224 Téléchargements
