Human brain distinctiveness based on EEG spectral coherence connectivity. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Biomedical Engineering Année : 2014
The use of EEG biometrics, for the purpose of automatic people recognition, has received increasing attention in the recent years. Most of current analysis rely on the extraction of features characterizing the activity of single brain regions, like power-spectrum estimates, thus neglecting possible temporal dependencies between the generated EEG signals. However, important physiological information can be extracted from the way different brain regions are functionally coupled. In this study, we propose a novel approach that fuses spectral coherence based connectivity between different brain regions as a possibly viable biometric feature. The proposed approach is tested on a large dataset of subjects (N=108) during eyes-closed (EC) and eyes-open (EO) resting state conditions. The obtained recognition performances show that using brain connectivity leads to higher distinctiveness with respect to power-spectrum measurements, in both the experimental conditions. Notably, a 100% recognition accuracy is obtained in EC and EO when integrating functional connectivity between regions in the frontal lobe, while a lower 97.5% is obtained in EC (96.26% in EO) when fusing power spectrum information from parieto-occipital (centro-parietal in EO) regions. Taken together, these results suggest that functional connectivity patterns represent effective features for improving EEG-based biometric systems.
hal-00992996 , version 1 (19-05-2014)
Daria La Rocca, Patrizio Campisi, Balazs Vegso, Peter Cserti, Gyorgy Kozmann, et al.. Human brain distinctiveness based on EEG spectral coherence connectivity.. IEEE Transactions on Biomedical Engineering, 2014, to be published. ⟨10.1109/TBME.2014.2317881⟩. ⟨hal-00992996⟩
618 Consultations
0 Téléchargements
