Binary Labelings for Plane Quadrangulations and their Relatives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2011
Motivated by the bijection between Schnyder labelings of a plane triangulation and partitions of its inner edges into three trees, we look for binary labelings for quadrangulations (whose edges can be partitioned into two trees). Our labeling resembles many of the properties of Schnyder's one for triangulations: Apart from being in bijection with tree decompositions, paths in these trees allow to define the regions of a vertex such that counting faces in them yields an algorithm for embedding the quadrangulation, in this case on a 2-book. Furthermore, as Schnyder labelings have been extended to 3-connected plane graphs, we are able to extend our labeling from quadrangulations to a larger class of 2-connected bipartite graphs.
976-5549-1-PB.pdf (294.76 Ko) Télécharger le fichier
hal-00993747 , version 1 (20-05-2014)
Stefan Felsner, Clemens Huemer, Sarah Kappes, David Orden. Binary Labelings for Plane Quadrangulations and their Relatives. Discrete Mathematics and Theoretical Computer Science, 2011, special issue in honor of Laci Babai's 60th birthday: Combinatorics, Groups, Algorithms, and Complexity, Vol. 12 no. 3 (3), pp.115-138. ⟨10.46298/dmtcs.475⟩. ⟨hal-00993747⟩
Collections
TDS-MACS
131 Consultations
1118 Téléchargements
