Random Measurable Sets and Covariogram Realisability Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2014
Bruno Galerne
  • Fonction : Auteur
  • PersonId : 924934
We provide a characterization of the realisable set covariograms, bringing a rigorous yet abstract solution to the $S_2$ problem in materials science. Our method is based on the covariogram functional for random mesurable sets (RAMS) and on a result about the representation of positive operators in a locally compact space. RAMS are an alternative to the classical random closed sets in stochastic geometry and geostatistics, they provide a weaker framework allowing to manipulate more irregular functionals, such as the perimeter. We therefore use the illustration provided by the $S_{2}$ problem to advocate the use of RAMS for solving theoretical problems of geometric nature. Along the way, we extend the theory of random measurable sets, and in particular the local approximation of the perimeter by local covariograms.
reaper.pdf (361.05 Ko) Télécharger le fichier
hal-00995853 , version 1 (24-05-2014)
hal-00995853 , version 2 (09-07-2014)
hal-00995853 , version 3 (28-02-2015)
Bruno Galerne, Raphael Lachieze-Rey. Random Measurable Sets and Covariogram Realisability Problems. 2014. ⟨hal-00995853v1⟩
234 Consultations
153 Téléchargements
