Bregman superquantiles. Estimation methods and applications. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In this work, we extend some quantities introduced in "Optimization of conditional value-at-risk" of R.T Rockafellar and S. Uryasev to the case where the proximity between real numbers is measured by using a Bregman divergence. This leads to the definition of the Bregman superquantile. Axioms of a coherent measure of risk discussed in "Coherent approches to risk in optimization under uncertainty" of R.T Rockafellar are studied in the case of Bregman superquantile. Furthermore, we deal with asymptotic properties of a Monte Carlo estimator of the Bregman superquantile.
septembre2015.pdf (467.36 Ko) Télécharger le fichier
hal-00996440 , version 1 (26-05-2014)
hal-00996440 , version 2 (20-10-2014)
hal-00996440 , version 3 (23-10-2014)
hal-00996440 , version 4 (19-11-2014)
hal-00996440 , version 5 (19-11-2014)
hal-00996440 , version 6 (06-05-2015)
hal-00996440 , version 7 (08-09-2015)
hal-00996440 , version 8 (06-01-2016)
Tatiana Labopin-Richard, Fabrice Gamboa, Aurélien Garivier, Bertrand Iooss. Bregman superquantiles. Estimation methods and applications.. 2014. ⟨hal-00996440v7⟩
507 Consultations
349 Téléchargements
