Optimal transport bounds between the time-marginals of a multidimensional diffusion and its Euler scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In this paper, we prove that the time supremum of the Wasserstein distance between the time-marginals of a uniformly elliptic multidimensional diffusion with coefficients bounded together with their derivatives up to the order $2$ in the spatial variables and Hölder continuous with exponent $\gamma$ with respect to the time variable and its Euler scheme with $N$ uniform time-steps is smaller than $C \left(1+\mathbf{1}_{\gamma=1} \sqrt{\ln(N)}\right)N^{-\gamma}$. To do so, we use the theory of optimal transport. More precisely, we investigate how to apply the theory by Ambrosio, Gigli and Savaré to compute the time derivative of the Wasserstein distance between the time-marginals. We deduce a stability inequality for the Wasserstein distance which finally leads to the desired estimation.
Optimaltransportbounds.pdf (288.38 Ko) Télécharger le fichier
hal-00997301 , version 1 (27-05-2014)
hal-00997301 , version 2 (19-03-2015)
Aurélien Alfonsi, Benjamin Jourdain, Arturo Kohatsu-Higa. Optimal transport bounds between the time-marginals of a multidimensional diffusion and its Euler scheme. 2014. ⟨hal-00997301v1⟩
330 Consultations
247 Téléchargements
