Superdiffusion of energy in a chain of harmonic oscillators with noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We consider a one dimensional infinite chain of harmonic oscillators whose dynamics is perturbed by a stochastic term conserving energy and momentum. We prove that in the unpinned case the macroscopic evolution of the energy converges to a fractional diffusion governed by $\Delta|^{3/4}$. For a pinned system we prove that energy evolves diffusively, generalizing some of the results of [4].
jkosuper-arxiv2b.pdf (466.4 Ko) Télécharger le fichier
hal-00997642 , version 1 (28-05-2014)
hal-00997642 , version 2 (23-02-2015)
hal-00997642 , version 3 (20-06-2015)
  • HAL Id : hal-00997642 , version 1
Milton Jara, Tomasz Komorowski, Stefano Olla. Superdiffusion of energy in a chain of harmonic oscillators with noise. 2014. ⟨hal-00997642v1⟩
666 Consultations
192 Téléchargements
