New interface
Journal articles
Aggregation of local parametric candidates with exemplar-based occlusion handling for optical flow
Abstract : Handling all together large displacements, motion details and occlusions remains an open issue for reliable computation of optical flow in a video sequence. We propose a two-step aggregation paradigm to address this problem. The idea is to supply local motion candidates at every pixel in a first step, and then to combine them to determine the global optical flow field in a second step. We exploit local parametric estimations combined with patch correspondences and we experimentally demonstrate that they are sufficient to produce highly accurate motion candidates. The aggregation step is designed as the discrete optimization of a global regularized energy. The occlusion map is estimated jointly with the flow field throughout the two steps. We propose a generic exemplar-based approach for occlusion filling with motion vectors. We achieve state-of-the-art results in computer vision benchmarks, with particularly significant improvements in the case of large displacements and occlusions.
Document type :
Journal articles
Complete list of metadata
Cited literature [90 references]  Display  Hide  Download
https://hal.inria.fr/hal-01001758
Contributor : Denis Fortun Connect in order to contact the contributor
Submitted on : Tuesday, December 22, 2015 - 3:19:43 PM
Last modification on : Monday, July 25, 2022 - 3:44:44 AM
Long-term archiving on: : Sunday, April 30, 2017 - 12:06:27 AM
File
CVIU_aggreg_revision.pdf
Identifiers
Citation
Denis Fortun, Patrick Bouthemy, Charles Kervrann. Aggregation of local parametric candidates with exemplar-based occlusion handling for optical flow. Computer Vision and Image Understanding, 2016, pp.17. ⟨10.1016/j.cviu.2015.11.020⟩. ⟨hal-01001758v2⟩
Share
Metrics
Record views
148
Files downloads
169
