Racing Multi-Objective Selection Probabilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2014
In the context of Noisy Multi-Objective Optimization, dealing with uncertainties requires the decision maker to define some preferences about how to handle them, through some statistics (e.g., mean, median) to be used to evaluate the solution qualities, and define the corresponding Pareto set. Approximating these statistics requires repeated samplings of the population, drastically increasing the overall computational cost. To tackle this issue, this paper proposes to use some Hoeffding race to directly estimate the probability of each individual to be selected using a minimum number of samples, dynamically assigning the estimation budget during the selection step. The proposed racing approach is validated against static budget approaches with NSGA-II on noisy versions of the ZDT benchmark functions.
Fichier non déposé
hal-01002854 , version 1 (06-06-2014)
  • HAL Id : hal-01002854 , version 1
Gaétan Marceau, Marc Schoenauer. Racing Multi-Objective Selection Probabilities. 2014. ⟨hal-01002854⟩
89 Consultations
0 Téléchargements
