Abstract : Conventional neural field models describe well some experimental data, such as Local Field Potentials or electroencephalographic data. The work reviews recent extensions of neural field models and describes the activation and attenuation of spectral power in certain frequency bands subjected to the statistical properties of an external input and subjected to the properties of synaptic receptor efficacy and the heteroclinic transitions between meta-stable state as a model for event-related potentials.
