An OSGi Monitoring System with Dynamicity Resilience enhancing Fault Tolerance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yufang Dan
  • Fonction : Auteur
  • PersonId : 924951
Nicolas Stouls
Stéphane Frénot
In the context of Dynamic Service-oriented Architecture(SOA), where services may dynamically appear or disappear transparently to the user, if a reference of disap- peared service is used by another service, classical monitoring systems can't deal with the use of such stale reference, even though the monitoring system has dynamicity resilience (i.e., OSGiLarva). In this paper, we propose a monitoring system, named NewMS, which has dynamicity resilience as well as capability of handling stale references without restarting monitored systems
Fichier non déposé
hal-01009780 , version 1 (18-06-2014)
  • HAL Id : hal-01009780 , version 1
Yufang Dan, Nicolas Stouls, Stéphane Frénot. An OSGi Monitoring System with Dynamicity Resilience enhancing Fault Tolerance. International Conferences on Software and Computing Technology, Aug 2014, Lijiang, China. ⟨hal-01009780⟩
173 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
