Density-controlled crowds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We present a novel algorithm for populating and animating an environment of a given density. Our algorithm considers two kind of densities: static density (when people doesn't move) and dynamic density (when people move). The resulting flows of characters are computed according to a density map provided by a user. We discuss the advantages and drawbacks of the proposed solution, as well as future work.
CrowdDensity-SCA2014.pdf (474.8 Ko) Télécharger le fichier
Format : Figure, Image
hal-01015118 , version 1 (09-10-2015)
  • HAL Id : hal-01015118 , version 1
Kevin Jordao, Julien Pettré, Marie-Paule Cani. Density-controlled crowds. Symposition on Computer Animation, Jul 2014, Copenhagen, Denmark. 2014. ⟨hal-01015118⟩
1595 Consultations
88 Téléchargements
