Wigner and Kondo physics in quantum point contacts revealed by scanning gate microscopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Communications Année : 2014
Ulf Gennser
Serge Huant
  • Fonction : Auteur
  • PersonId : 957039
Quantum point contacts exhibit mysterious conductance anomalies in addition to well known conductance plateaus at multiples of 2e²/h. These 0.7 and zero-bias anomalies have been intensively studied, but their microscopic origin in terms of many-body effects is still highly debated. Here we use the charged tip of a scanning gate microscope to tune in situ the electrostatic potential of the point contact. While sweeping the tip distance, we observe repetitive splittings of the zero-bias anomaly, correlated with simultaneous appearances of the 0.7 anomaly. We interpret this behaviour in terms of alternating equilibrium and non-equilibrium Kondo screenings of different spin states localized in the channel. These alternating Kondo effects point towards the presence of a Wigner crystal containing several charges with different parities. Indeed, simulations show that the electron density in the channel is low enough to reach one-dimensional Wigner crystallization over a size controlled by the tip position.
1307.8328.pdf (5.93 Mo) Télécharger le fichier
hal-01015395 , version 1 (17-04-2024)
Boris Brun, Frederico Martins, Sebastien Faniel, Benoit Hackens, Guillaume Bachelier, et al.. Wigner and Kondo physics in quantum point contacts revealed by scanning gate microscopy. Nature Communications, 2014, 5, pp.4290. ⟨10.1038/ncomms5290⟩. ⟨hal-01015395⟩
290 Consultations
0 Téléchargements
