Mode Selective Actuator-Sensor System for Lamb Wave-Based Structural Health Monitoring
Structural Health Monitoring (SHM) based on Lamb waves, a type of ultrasonic guided waves, is a promising method for in-service inspection of composite structures. In this study mode selective actuators and sensors are investigated to excite a particular Lamb wave mode in composite plates. The actuator and sensor exhibit an interdigital transducer design. In order to describe the complex displacement fields of
