Algorithms Hardware Implementation for Ultrasonic Data Processing in SHM System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays, devices that monitor the health of structures consume a lot of power and need a lot of time to acquire, process, and send the information about the structure to the main processing unit. To decrease this time, fast electronic devices are starting to be used to accelerate this processing. In this paper some hardware algorithms implemented in an electronic logic programming device are described. The goal of this implementation is accelerate the process and diminish the information that has to be send. By reaching this goal, the time the processor needs for treating all the information is reduced and so the power consumption is reduced too.
0073.pdf (527.82 Ko) Télécharger le fichier
hal-01020458 , version 1 (08-07-2014)
  • HAL Id : hal-01020458 , version 1
Javier Alonso-Alegre, Adolfo García-Corcuera, Gerardo Aranguren, Pedro M. Monje, Ángel Alcaide Pardo, et al.. Algorithms Hardware Implementation for Ultrasonic Data Processing in SHM System. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020458⟩
129 Consultations
155 Téléchargements
