Ply Level Uncertainty Effects on Failure of Composite Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Composite materials are popular in aerospace engineering because of their light weight, high strength to weight ratio, stiffness to weight ratio and tailoring properties. However, the modeling of composites is still a challenging task because of its highly uncertain material properties which arise from the manufacturing process.The effect of material uncertainties in failure strength and reliability analysis for single ply and cross ply laminated composite subjected to only axial loading is studied in this work. Researchers have categorized the uncertainty at different scales. Meso-scale uncertainty, that is ply level uncertainty, is being considered here. In this paper, the ply level uncertainties are taken as basic random variables and the strength parameters of the composite are derived through uncertainty propagation considering both Tsai-Wu and Maximum stress criteria. Monte Carlo simulation is performed to quantify uncertainty effects.
0264.pdf (758.33 Ko) Télécharger le fichier
hal-01021047 , version 1 (09-07-2014)
  • HAL Id : hal-01021047 , version 1
Shuvajit Mukherjee, Ranjan Ganguli, S Gopalakrishnan, Léa Dominique Cot, Christian Bes. Ply Level Uncertainty Effects on Failure of Composite Structures. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021047⟩
384 Consultations
321 Téléchargements
