SHM Based on Modal Analysis: Accelerometer and Piezoelectric Transducers Instrumentation for Civil Engineering in Heterogeneous Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a strategy for the detection of mechanical damage of a reinforced concrete beam strengthened by Carbon Fiber Reinforced Polymers (CFRP) sheets (TFC ©) based on the joint use of piezoelectric sensors and conventional accelerometers. The beam is subjected to repeat impacts that may represent the action of vehicles on a roadway joint of a bridge, at different levels of damage induce by bending of the reinforced concrete beam. The results show that piezoelectric sensors provide a much wide response those accelerometers allowing a study in the high frequency range (above 2 kHz). The spectral response appears largely affected by mechanical damage on the beam and suggests a possible use for SHM in Civil Engineering structures.
0279.pdf (653.65 Ko) Télécharger le fichier
hal-01021063 , version 1 (09-07-2014)
  • HAL Id : hal-01021063 , version 1
Andrés Belisario-Briceño, Sabeha Fettouma Zedek, Thierry Camps, Raoul François, Christophe Escriba, et al.. SHM Based on Modal Analysis: Accelerometer and Piezoelectric Transducers Instrumentation for Civil Engineering in Heterogeneous Structures. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021063⟩
527 Consultations
1807 Téléchargements
