Smart Textile Reinforced Concrete Sensory Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study examines and demonstrates the feasibility of a new class of smart textile reinforced concrete (TRC) structural elements with inherent sensing capabilities that are based on embedding metallic yarns in the textile mesh. The new approach combines the advantages of thin walled glass fiber based TRC with the electro-mechanical properties of the stainless steel fibers embedded in the textile matrix. To examine this concept and to demonstrate its potential feasibility, TRC beam specimens are tested and monitored under mechanical and environmental loading condition. The results of the tests demonstrate the features of the sensory/structural system, reveals its potential use as a basis for a combined structural and functional monitoring system, and highlights its spectrum of potential applications.
0388.pdf (664.28 Ko) Télécharger le fichier
hal-01022059 , version 1 (10-07-2014)
  • HAL Id : hal-01022059 , version 1
Yiska Goldfeld, Oded Rabinovitch, Till Quadflieg, Barak Fishbain, Thomas Gries. Smart Textile Reinforced Concrete Sensory Structures. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022059⟩
350 Consultations
375 Téléchargements
