YaMTG: An Open-Source Heavily Multilingual Translation Graph Extracted from Wiktionaries and Parallel Corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes YaMTG (Yet another Multilingual Translation Graph), a new open-source heavily multilingual translation database (over 664 languages represented) built using several sources, namely various wiktionaries and the OPUS parallel corpora (Tiedemann, 2009). We detail the translation extraction process for 21 wiktionary language editions, and provide an evaluation of the translations contained in YaMTG.
lrec14tradgraph.pdf (231.91 Ko) Télécharger le fichier
hal-01022306 , version 1 (10-07-2014)
  • HAL Id : hal-01022306 , version 1
Valérie Hanoka, Benoît Sagot. YaMTG: An Open-Source Heavily Multilingual Translation Graph Extracted from Wiktionaries and Parallel Corpora. Language Resources and Evaluation Conference, European Language Resources Association, May 2014, Reykjavik, Iceland. ⟨hal-01022306⟩
179 Consultations
296 Téléchargements
