A Morphological Analysis of Audio Objects and their Control Methods for 3D Audio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent technological improvements in audio reproduction systems increased the possibilities to spatialize sources in a listening environment. The spatialization of reproduced audio is highly dependent on the recording technique, the rendering method, and the loudspeaker configuration. While object-based audio production reduces this dependency on loudspeaker configurations, related authoring tools are still difficult to interact with. In this paper, we investigate the issues of spatialization techniques for object-based audio production and introduce the Spatial Audio Design Spaces framework (SpADS), which describes the spatial manipulation of object-based audio. Based on interviews with professional sound engineers, our morphological analysis clarifies the relationships between recording and rendering techniques that define audio objects for 3D speaker configurations, allowing the analysis and the design of advanced object-based controllers as well.
NIME2014_main_HAL.pdf (1.58 Mo) Télécharger le fichier
hal-01022825 , version 1 (11-07-2014)
  • HAL Id : hal-01022825 , version 1
Justin Mathew, Stéphane Huot, Alan Blum. A Morphological Analysis of Audio Objects and their Control Methods for 3D Audio. NIME 2014 - 14th International Conference on New Interfaces for Musical Expression, Jun 2014, London, United Kingdom. ⟨hal-01022825⟩
418 Consultations
628 Téléchargements
