Scheduled and SHM Structural Airframe Maintenance Applications Using a New Probabilistic Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yiwei Wang
  • Fonction : Auteur
  • PersonId : 771957
  • IdRef : 203628039
Christian Bes
Christian Gogu
This paper focuses on aircraft structure maintenance. A general mathematical framework based on a probabilistic analytical model was developed to provide the average number of fuselage panels to be replaced after any number of cycles and over the aircraft lifetime under fatigue damage failure. This paper proposes a study to explore structure maintenance strategies using this analytical model. Both scheduled maintenance and condition-based maintenance using SHM are considered for different aircrafts with different lifetimes and timetable inspections. In each case, the aircraft lifecycle cost is evaluated in terms of average number of panels changed. A similar study based on Monte Carlo method was carried out and we studied the results given by this approach considering same maintenance strategies as mentioned above. Because the simulation conditions are not exactly the same, the results obtained using the PAM are a little bit different than the ones obtained by Monte Carlo simulations, indeed, it shows an adequacy. Compared to Monte Carlo method, the analytical model is of a great interest regarding the accuracy because the recurrence formula leads to an exact expression of the average number of fuselage panels to be replaced.
0238.pdf (185.92 Ko) Télécharger le fichier
hal-01022994 , version 1 (11-07-2014)
  • HAL Id : hal-01022994 , version 1
Léa Dominique Cot, Yiwei Wang, Christian Bes, Christian Gogu. Scheduled and SHM Structural Airframe Maintenance Applications Using a New Probabilistic Model. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022994⟩
342 Consultations
192 Téléchargements
