Conference papers
On the Damage Diagnosis Based on Structural Analysis Data
Abstract : One of the major challenges of Structural Health Monitoring (SHM) is to handle the enormous amount of data during the monitoring action. This is due to the fact that common SHM approaches monitor the entire structure on all kind of damages in order to obtain all eventualities of damage. The idea of this contribution is to use the information of the partÕs sizing in order to identify so called hot spots, i.e. possible damage locations and the corresponding kind of damage like cracks or delaminations. With this information a SmartSHM system is set up, which monitors only the hot spots on the most likely failure. To cover uncertainties and accidental damages an additional monitoring of a global parameter has to be set up. This approach is shown based on an example of a four point bending test with a rectangular cross-section.
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01022996
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Tuesday, July 15, 2014 - 1:36:04 PM
Last modification on : Friday, May 28, 2021 - 5:08:01 PM
Long-term archiving on: : Friday, November 21, 2014 - 5:25:14 PM
File
OnTheDamageDiagnosisBasedOnStr...
Identifiers
  • HAL Id : hal-01022996, version 2
Collections
Citation
Kai-Uwe Schröder, Andreas Preisler, Christoph Viechtbauer, Martin Schagerl. On the Damage Diagnosis Based on Structural Analysis Data. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022996v2⟩
Share
Metrics
Record views
497
Files downloads
267
