Stein estimation of the intensity of a spatial homogeneous Poisson point process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2014
Marianne Clausel
Jean-François Coeurjolly
In this paper, we revisit the original ideas of Stein and propose an estimator of the intensity parameter of a homogeneous Poisson point process defined in $\R^d$ and observed in a bounded window. The procedure is based on a new general integration by parts formula for Poisson point processes. We show that our Stein estimator outperforms the maximum likelihood estimator in terms of mean squared error. In particular, we show that in many practical situations we have a gain larger than 30\%.
steinIPP.pdf (381.49 Ko) Télécharger le fichier
hal-01024648 , version 1 (16-07-2014)
hal-01024648 , version 2 (19-03-2015)
hal-01024648 , version 3 (30-07-2015)
Marianne Clausel, Jean-François Coeurjolly, Jérôme Lelong. Stein estimation of the intensity of a spatial homogeneous Poisson point process. 2014. ⟨hal-01024648v1⟩
503 Consultations
507 Téléchargements
