2-Point-based Outlier Rejection for Camera-Imu Systems with applications to Micro Aerial Vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a novel method to perform the outlier rejection task between two different views of a camera rigidly attached to an Inertial Measurement Unit (IMU). Only two feature correspondences and gyroscopic data from IMU measurerments are used to compute the motion hypothesis. By exploiting this 2-point motion parametrization, we propose two algorithms to remove wrong data associations in the featurematching process for case of a 6DoF motion. We show that in the case of a monocular camera mounted on a quadrotor vehicle, motion priors from IMU can be used to discard wrong estimations in the framework of a 2-point-RANSAC based approach. The proposed methods are evaluated on both synthetic and real data.
ICRA_2014_v2.pdf (1.19 Mo) Télécharger le fichier
hal-01024890 , version 1 (16-07-2014)
  • HAL Id : hal-01024890 , version 1
Chiara Troiani, Agostino Martinelli, Christian Laugier, Davide Scaramuzza. 2-Point-based Outlier Rejection for Camera-Imu Systems with applications to Micro Aerial Vehicles. 2014 IEEE International Conference on Robotics and Automation (ICRA), May 2014, Hong Kong, Hong Kong SAR China. ⟨hal-01024890⟩
671 Consultations
913 Téléchargements
