Journal articles
Optimization of jet parameters to control the flow on a ramp
Abstract : This study deals with the use of optimization algorithms to determine efficient parameters of flow control devices. To improve the performance of systems characterized by detached flows and vortex shedding, the use of flow control devices such as oscillatory jets are intensively studied. However, the determination of efficient control parameters is still a bottleneck for industrial problems. Therefore, we propose to couple a global optimization algorithm with an unsteady flow simulation to derive efficient flow control rules. We consider as a test case a backward-facing step with a slope of 25◦, including a synthetic jet actuator. The aim is to reduce the time-averaged recirculation length behind the step by optimizing the jet blowing/suction amplitude and frequency.
Document type :
Journal articles
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01025269
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Tuesday, July 22, 2014 - 4:44:10 PM
Last modification on : Sunday, May 1, 2022 - 3:15:08 AM
Long-term archiving on: : Monday, November 24, 2014 - 5:55:49 PM
File
CRAS_2014.pdf
Identifiers
Relations
Citation
Emmanuel Guilmineau, Régis Duvigneau, Jérémie Labroquère. Optimization of jet parameters to control the flow on a ramp. Comptes rendus de l’Académie des sciences. Série IIb, Mécanique, Elsevier, 2014, 342 (6-7), pp.363--375. ⟨10.1016/j.crme.2013.12.009⟩. ⟨hal-01025269⟩
Share
Metrics
Record views
353
Files downloads
344
