Optimization of jet parameters to control the flow on a ramp - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l’Académie des sciences. Série IIb, Mécanique Année : 2014
This study deals with the use of optimization algorithms to determine efficient parameters of flow control devices. To improve the performance of systems characterized by detached flows and vortex shedding, the use of flow control devices such as oscillatory jets are intensively studied. However, the determination of efficient control parameters is still a bottleneck for industrial problems. Therefore, we propose to couple a global optimization algorithm with an unsteady flow simulation to derive efficient flow control rules. We consider as a test case a backward-facing step with a slope of 25◦, including a synthetic jet actuator. The aim is to reduce the time-averaged recirculation length behind the step by optimizing the jet blowing/suction amplitude and frequency.
CRAS_2014.pdf (1.72 Mo) Télécharger le fichier
hal-01025269 , version 1 (22-07-2014)
Emmanuel Guilmineau, Régis Duvigneau, Jérémie Labroquère. Optimization of jet parameters to control the flow on a ramp. Comptes rendus de l’Académie des sciences. Série IIb, Mécanique, 2014, 342 (6-7), pp.363--375. ⟨10.1016/j.crme.2013.12.009⟩. ⟨hal-01025269⟩
Relations
366 Consultations
388 Téléchargements
