On the consistency of Sobol indices with respect to stochastic ordering of model parameters. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In the past decade, Sobol's variance decomposition have been used as a tool - among others - in risk management. We show some links between global sensitivity analysis and stochastic ordering theories. This gives an argument in favor of using Sobol's indices in uncertainty quantification, as one indicator among others.
CJMN17072014.pdf (325.53 Ko) Télécharger le fichier
hal-01026373 , version 1 (21-07-2014)
hal-01026373 , version 2 (21-07-2014)
  • HAL Id : hal-01026373 , version 1
Areski Cousin, Alexandre Janon, Véronique Maume-Deschamps, Ibrahima Niang. On the consistency of Sobol indices with respect to stochastic ordering of model parameters.. 2014. ⟨hal-01026373v1⟩
Collections
ICJ
783 Consultations
458 Téléchargements
