Microsaccades enable efficient synchrony-based visual feature learning and detection
Fixational eye movements are common across vertebrates, yet their functional roles, if any, are debated. To investigate this issue, we exposed the Virtual Retina simulator to natural images, generated realistic drifts and microsaccades using the model of ref, and analyzed the output spike trains of the parvocellular retinal ganglion cells (RGC).
Neurosciences [q-bio.NC]
1471-2202-15-S1-P121.pdf (136.75 Ko)
Télécharger le fichier
1471-2202-15-S1-P121.xml (8.4 Ko)
Format : Autre
