Adaptation of Asynchronously Communicating Software
Software adaptation techniques aim at generating new components called adapters, which make a set of services work correctly together by compensating for existing mismatch. Most approaches assume that services interact synchronously using rendez-vous communication. In this paper, we focus on asynchronous communication, where services interact exchanging messages via buffers. We overview a method for automatically generating adapters in such asynchronous environments.
Génie logiciel [cs.SE]
