Mixing Identities with Ease - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Patrik Bichsel
  • Fonction : Auteur
Jan Camenisch
  • Fonction : Auteur
Anonymous credential systems are a key ingredient for a secure and privacy protecting electronic world. In their full-fledged form, they can realize a broad range of requirements of authentication systems. However, these many features result in a complex system that can be difficult to use. In this paper, we aim to make credential systems easier to employ by providing an architecture and high-level specifications for the different components, transactions and features of the identity mixer anonymous credential system. The specifications abstract away the cryptographic details but they are still sufficiently concrete to enable all features. We demonstrate the use of our framework by applying it to an e-cash scenario.
idmxArch.pdf (292.89 Ko) Télécharger le fichier
hal-01054404 , version 1 (06-08-2014)
Paternité
Patrik Bichsel, Jan Camenisch. Mixing Identities with Ease. Second IFIP WG 11.6 Working Conference on Policies and Reseach Management (IDMAN), Nov 2010, Oslo, Norway. pp.1-17, ⟨10.1007/978-3-642-17303-5_1⟩. ⟨hal-01054404⟩
114 Consultations
188 Téléchargements
