On Packing Splittable Items with Cardinality Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper continues the study of the the allocation of memory to processors in a pipeline problem. This problem can be modeled as a variation of bin packing where each item corresponds to a different type and the normalized weight of each item can be greater than 1, which is the size of a bin. Furthermore, in this problem, items may be split arbitrarily, but each bin may contain at most k types of items, for any fixed integer k ≥ 2. The case of k = 2 was first introduced by Chung el al. who gave a 3/2-approximation asymptotically. In this paper, we generalize the result of Chung et al. to higher k. We show that NEXT FIT gives a $\left(1+\frac 1 k\right)$-approximation asymptotically, for k ≥ 2. Also, as a minor contribution, we rewrite the strong NP-hardness proof of Epstein and van Stee for this problem for k ≥ 3.
03230101.pdf (95.85 Ko) Télécharger le fichier
hal-01054441 , version 1 (06-08-2014)
Paternité
Fouad B. Chedid. On Packing Splittable Items with Cardinality Constraints. 6th IFIP TC 1/WG 2.2 International Conference on Theoretical Computer Science (TCS) / Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.101-110, ⟨10.1007/978-3-642-15240-5_8⟩. ⟨hal-01054441⟩
72 Consultations
147 Téléchargements
