An Infrastructure for Flexible Runtime Reconfigurable Multi-Microcontroller Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Claudius Stern
  • Fonction : Auteur
Philipp Adelt
  • Fonction : Auteur
Matthias Schmitz
  • Fonction : Auteur
Lisa Kleinjohann
  • Fonction : Auteur
Bernd Kleinjohann
  • Fonction : Auteur
Embedded systems in robotics or mechatronics need flexibility since they are working in dynamic environments. We consider an embedded modular multi-microcontroller system. Each module includes a microcontroller and special purpose hardware like a motor driver. Usually a change of the embedded software necessitates a direct access to all the devices (microcontrollers) to reload the code. To overcome this disadvantage we introduce an infrastructure for flexible runtime reconfiguration of microcontroller modules within a system. The infrastructure enables the system to be coarse-grain reconfigurable on module level from one single point of access. By using our infrastructure the system can remain operational during reconfiguration except the modules that actually get reconfigured. The infrastructure can cope with hardware changes during runtime like disconnection and reconnection of system parts.
final_018.pdf (524.14 Ko) Télécharger le fichier
hal-01054498 , version 1 (07-08-2014)
Paternité
Claudius Stern, Philipp Adelt, Matthias Schmitz, Lisa Kleinjohann, Bernd Kleinjohann. An Infrastructure for Flexible Runtime Reconfigurable Multi-Microcontroller Systems. 7th IFIP TC 10 Working Conference on Distributed, Parallel and Biologically Inspired Systems (DIPES) / 3rd IFIP TC 10 International Conference on Biologically-Inspired Collaborative Computing (BICC) / Held as Part of World Computer Congress (WCC) , Sep 2010, Brisbane, Australia. pp.205-216, ⟨10.1007/978-3-642-15234-4_20⟩. ⟨hal-01054498⟩
647 Consultations
460 Téléchargements
