Learning Motor Control by Dancing YMCA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To be able to generate desired movements a robot needs to learn which motor commands move the limb from one position to another. We argue that learning by imitation might be an efficient way to acquire such a function, and investigate favorable properties of the movement used during training in order to maximize the control system's generalization capabilities. Our control system was trained to imitate one particular movement and then tested to see if it can imitate other movements without further training.
lovlid_IFIPAI2010.pdf (911.26 Ko) Télécharger le fichier
hal-01054581 , version 1 (07-08-2014)
Paternité
Rikke Amilde Lävlid. Learning Motor Control by Dancing YMCA. Third IFIP TC12 International Conference on Artificial Intelligence (AI) / Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.79-88, ⟨10.1007/978-3-642-15286-3_8⟩. ⟨hal-01054581⟩
91 Consultations
199 Téléchargements
