Modelling Railway Interlocking Tables Using Coloured Petri Nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Interlocking tables are the functional specification defining the routes, on which the passage of the train is allowed. Associated with the route, the states and actions of all related signalling equipment are also specified. This paper formally models the interlocking tables using Coloured Petri Nets (CPN). The CPN model comprises two parts: Signaling Layout and Interlocking Control. The Signaling Layout part is used to simulate the passage of the train. It stores geographic information of the signalling layout in tokens. The Interlocking Control part models actions of the controller according to the functions specified in the interlocking tables. The arc inscriptions in the model represent the content of the interlocking tables. Following our modelling approach we can reuse the same CPN net structure to model any new or modified interlocking system regardless of its size. Experimental results are presented to provide increased confidence in the model correctness.
COOR2010-SSV-Interlocking.pdf (282.85 Ko) Télécharger le fichier
hal-01054630 , version 1 (07-08-2014)
Paternité
Somsak Vanit-Anunchai. Modelling Railway Interlocking Tables Using Coloured Petri Nets. 12th International Conference on Coordination Models and Languages (COORDINATION) Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.137-151, ⟨10.1007/978-3-642-13414-2_10⟩. ⟨hal-01054630⟩
178 Consultations
1986 Téléchargements
