Distribution and Dependence of Extremes in Network Sampling Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We explore the dependence structure in the sampled sequence of large networks. We consider randomized algorithms to sample the nodes and study extremal properties in any associated stationary sequence of characteristics of interest like node degrees, number of followers or income of the nodes in Online Social Networks etc, which satisfy two mixing conditions. Several useful extremes of the sampled sequence like $k$th largest value, clusters of exceedances over a threshold, first hitting time of a large value etc are investigated. We abstract the dependence and the statistics of extremes into a single parameter that appears in Extreme Value Theory, called extremal index (EI). In this work, we derive this parameter analytically and also estimate it empirically. We propose the use of EI as a parameter to compare different sampling procedures. As a specific example, degree correlations between neighboring nodes are studied in detail with three prominent random walks as sampling techniques.
RR-8578.pdf (609.31 Ko) Télécharger le fichier
hal-01054929 , version 1 (10-08-2014)
hal-01054929 , version 2 (11-08-2014)
hal-01054929 , version 3 (24-02-2015)
Konstantin Avrachenkov, Natalia M. Markovich, Jithin K. Sreedharan. Distribution and Dependence of Extremes in Network Sampling Processes. [Research Report] RR-8578, Inria. 2014, pp.19. ⟨hal-01054929v2⟩
138 Consultations
243 Téléchargements
