Reactive Semantics for Distributed UML Activities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We define a reactive semantics for a subset of UML activities that is suitable as precise design language for reactive software systems. These semantics identify run-to-completion steps for execution on the level of UML activities as so-called activity steps. We show that activities adhering to these semantics and a set of rules lead to event-driven and bounded specifications that can be implemented automatically by model transformations and executed efficiently using runtime support systems.
61170017.pdf (409.15 Ko) Télécharger le fichier
hal-01055149 , version 1 (11-08-2014)
Paternité
Frank Alexander Kraemer, Peter Herrmann. Reactive Semantics for Distributed UML Activities. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.17-31, ⟨10.1007/978-3-642-13464-7_3⟩. ⟨hal-01055149⟩
103 Consultations
164 Téléchargements
