Heap-Dependent Expressions in Separation Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Separation logic is a popular specification language for imperative programs where the heap can only be mentioned through points-to assertions. However, separation logic's take on assertions does not match well with the classical view of assertions as boolean, side effect-free, potentially heap-dependent expressions from the host programming language familiar to many developers. In this paper, we propose a variant of separation logic where side effect-free expressions from the host programming language, such as pointer dereferences and invocations of pure methods, can be used in assertions. We modify the symbolic execution-based verification algorithm used in Smallfoot to support mechanized checking of our variant of separation logic. We have implemented this algorithm in a tool and used the tool to verify some interesting programming patterns.
61170168.pdf (219.65 Ko) Télécharger le fichier
hal-01055155 , version 1 (11-08-2014)
Paternité
Jan Smans, Bart Jacobs, Frank Piessens. Heap-Dependent Expressions in Separation Logic. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.170-185, ⟨10.1007/978-3-642-13464-7_14⟩. ⟨hal-01055155⟩
113 Consultations
161 Téléchargements
