Methods for Efficient Development of Task-Based Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces methods for developing task-based applications by tightly integrating workflows with application logic written in an imperative programming language and automatically completing workflows especially with tasks that mediate interaction with users. Developers are then provided with completed workflow they may be used for further development. Automatic completion of workflows should enable to significantly shorten the development process and eliminate repetitive and error-prone development tasks. Information extracted from workflow structure and low level application logic may then be used to automatically generate low to high fidelity prototype user interfaces for different devices and contexts.
Methods_for_efficient_development_of_task-based_applications_-_after_review.pdf (180.36 Ko) Télécharger le fichier
hal-01055202 , version 1 (11-08-2014)
Paternité
Vaclav Slovacek. Methods for Efficient Development of Task-Based Applications. Third IFIP WG 13.2 International Conference on Human-Centred Software Engineering (HCSE), Oct 2010, Reykjavik, Iceland. pp.206-213, ⟨10.1007/978-3-642-16488-0_18⟩. ⟨hal-01055202⟩
95 Consultations
161 Téléchargements
