A Dynamic Data Middleware Cache for Rapidly-Growing Scientific Repositories
Modern scientific repositories are growing rapidly
in size. Scientists are increasingly interested in viewing the latest
data as part of query results. Current scientific middleware cache
systems, however, assume repositories are static. Thus, they cannot
answer scientific queries with the latest data. The queries, instead,
are routed to the repository until data at the cache is refreshed. In
data-intensive scientific disciplines, such as astronomy, indiscriminate
query routing or data refreshing often results in runaway network costs.
This severely affects the performance and scalability of the
repositories and makes poor use of the cache system. We present Delta a
dynamic data middleware cache system for rapidly-growing scientific
repositories. Delta's key component is a decision framework that
adaptively decouples data objects--choosing to keep some data object at
the cache, when they are heavily queried, and keeping some data objects
at the repository, when they are heavily updated. Our algorithm profiles
incoming workload to search for optimal data decoupling that reduces
network costs. It leverages formal concepts from the network flow
problem, and is robust to evolving scientific workloads. We evaluate the
efficacy of Delta, through a prototype implementation, by running query
traces collected from a real astronomy survey.
