A Framework for Constructing Entertainment Contents Using Flash and Wearable Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multimedia interactive contents that can be controlled by user's motion attract a great deal of attention especially in entertainment such as gesture-based games. A system that provides such interactive contents detects the human motions using several body-worn sensors. To develop such a system, the contents creator must have enough knowledge about various sensors. In addition, since sensors and contents are deeply associated in contents, it is difficult to change/add sensors for such contents. In this paper, we propose a framework that helps contents creators who do not have enough knowledge on sensors. In our framework, an interactive content is divided into two layers; sensor management layer and content layer. We confirmed that creators can create interactive contents easier with our framework.
paper_final.pdf (866.04 Ko) Télécharger le fichier
hal-01055627 , version 1 (13-08-2014)
Paternité
Tsutomu Terada, Kohei Tanaka. A Framework for Constructing Entertainment Contents Using Flash and Wearable Sensors. 9th International Conference on Entertainment Computing (ICEC), Sep 2010, Seoul, South Korea. pp.334-341, ⟨10.1007/978-3-642-15399-0_35⟩. ⟨hal-01055627⟩
62 Consultations
141 Téléchargements
