Feasibility of Laser Induced Plasma Micro-machining (LIP-MM) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper offers evidence on the feasibility of a newly proposed micro-machining process, which is motivated by the need to overcome the various limitations associated with μ-EDM and conventional ultra-short laser micro-machining processes. The limitations in μ-EDM and laser micro-machining processes are mainly due to the requirement of a conductive electrode and workpiece, electrode wear and compensation strategies, and complex process control mechanisms respectively. The new process uses a laser beam to generate plasma in a dielectric near the workpiece surface whose explosive expansion results in material removal by mechanisms similar to those that occur in μ-EDM.
Paper_34_-_EHMANN.pdf (3.95 Mo) Télécharger le fichier
hal-01055662 , version 1 (13-08-2014)
Paternité
Kumar Pallav, Kornel F. Ehmann. Feasibility of Laser Induced Plasma Micro-machining (LIP-MM). 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.73-80, ⟨10.1007/978-3-642-11598-1_8⟩. ⟨hal-01055662⟩
57 Consultations
316 Téléchargements
