Challenges of Precision Assembly with a Miniaturized Robot
The first part of the paper describes the
miniaturized robot Parvus, which is suitable for desktop factory
applications. The Parvus is well equipped for pick-and-place of micro
parts in precision assembly. The challenges of precision assembly are
discussed considering the technical data and behavior of the robot. The
hybrid robot operates based on parallel kinematics and is driven by
micro harmonic drive gears. Due to its size-reduction, the Parvus offers
prospects, but also constraints which are discussed and presented by
measuring data. Finally, solutions for improving the precision of the
robot are presented.
Bibliothèque électronique [cs.DL]
