Vision and Force Sensing to Decrease Assembly Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
This paper presents two ways of decreasing the assembly uncertainty of micro assembly tasks through further or optimized integration of sensors within a size adapted assembly system. To accomplish this, the orientation of the part to be placed with respect to the vision sensor is changed. This was possible through a new gripper which was able to overcome the restrictions placed on the system by the vision sensor. Another increase in precision was obtained through the integration of a force sensor into the wrist of the robot. This force sensor provides additional information about the placing process which allows the maximal force in the vertical axis to be limited. These improvements are then demonstrated on a task which requires the placement of linear guides which are 8.4 millimeters by 1 millimeter.
Paper_3_-_ELLWOOD.pdf (434.33 Ko) Télécharger le fichier
Dates and versions
hal-01055693 , version 1 (13-08-2014)
Attribution
Identifiers
Cite
R. John Ellwood, Annika Raatz, Jürgen Hesselbach. Vision and Force Sensing to Decrease Assembly Uncertainty. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.123-130, ⟨10.1007/978-3-642-11598-1_14⟩. ⟨hal-01055693⟩
121 View
181 Download
Share
