Promoting Sustainability Awareness through Energy Engaged Virtual Communities of Construction Stakeholders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sustainability requires the engagement of every single constituent of the "building" product supply chain, from concept design to operation. The research explores ways of creating circles of impacts that bind building professionals, energy administrations, and citizens in a shared low carbon experience through a "one-stop-shop" Sustainable Construction Service Platform. The paper discusses awareness raising, stakeholders' engagement, technical requirements, and adoption and diffusion factors related to the platform. The research identifies the need to use advanced knowledge management functionality to leverage the value dimension of the proposed "one-stop-shop" service platform initiative.
pro16.pdf (63.73 Ko) Télécharger le fichier
hal-01056000 , version 1 (25-08-2014)
Paternité
Yacine Rezgui, Ian E. Wilson, Haijiang Li. Promoting Sustainability Awareness through Energy Engaged Virtual Communities of Construction Stakeholders. 11th IFIP WG 5.5 Working Conference on Virtual Enterprises (PRO-VE), Oct 2010, Saint-Etienne, France. pp.142-148, ⟨10.1007/978-3-642-15961-9_16⟩. ⟨hal-01056000⟩
139 Consultations
186 Téléchargements
