Generic Constructions of Biometric Identity Based Encryption Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a novel framework for the generic construction of biometric Identity Based Encryption (IBE) schemes, which do not require bilinear pairings and result in more efficient schemes than existing fuzzy IBE systems implemented for biometric identities. Also, we analyze the security properties that are specific to biometric IBE namely anonymity and identity privacy. Considering these notions, we present generic constructions for biometric IBE and ID-KEM based on weakly secure anonymous IBE schemes, error correcting codes and generic conversion schemes. Finally, we describe concrete applications of our framework and compare them to the existing fuzzy IBE systems in terms of time complexity.
60330092.pdf (214.46 Ko) Télécharger le fichier
hal-01056064 , version 1 (14-08-2014)
Paternité
Neyire Deniz Sarier. Generic Constructions of Biometric Identity Based Encryption Systems. 4th IFIP WG 11.2 International Workshop on Information Security Theory and Practices: Security and Privacy of Pervasive Systems and Smart Devices (WISTP), Apr 2010, Passau, Germany. pp.90-105, ⟨10.1007/978-3-642-12368-9_7⟩. ⟨hal-01056064⟩
205 Consultations
230 Téléchargements
