An Energy-Efficient Symmetric Cryptography Based Authentication Scheme for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sensor networks are ad-hoc mobile networks that include sensor nodes with limited computational and communication capabilities. They have become an economically viable monitoring solution for a wide variety of applications. Obviously, it is important to ensure security and, taking into account limited resources available in wireless sensor networks, the use of symmetric cryptography is strongly recommended. In this paper we present a light-weight authentication model for wireless sensor networks composed of a key management and an authentication protocol. It is based on simple symmetric cryptographic primitives with very low computational requirements, and it achieves better results than other similar proposals in the literature. Compared to SPINS and BROSK protocols, our system can reduce energy consumption by up to 98% and 67% respectively. It also scales well with the size of the network, due to it only requiring one interchanged message, regardless of the total number of nodes in the network.
60330335.pdf (134.75 Ko) Télécharger le fichier
hal-01056073 , version 1 (14-08-2014)
Paternité
Oscar Delgado-Mohatar, José M. Sierra, Ljiljana Brankovic, Amparo Fúster-Sabater. An Energy-Efficient Symmetric Cryptography Based Authentication Scheme for Wireless Sensor Networks. 4th IFIP WG 11.2 International Workshop on Information Security Theory and Practices: Security and Privacy of Pervasive Systems and Smart Devices (WISTP), Apr 2010, Passau, Germany. pp.332-339, ⟨10.1007/978-3-642-12368-9_27⟩. ⟨hal-01056073⟩
173 Consultations
123 Téléchargements
