Efficient and Effective Buffer Overflow Protection on ARM Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Although many countermeasures have been developed for desktop and server environments, buffer overflows still pose a big threat. The same approach can be used to target mobile devices. Unfortunately, they place more severe limitations on countermeasures. Not only are the performance requirements at least as important, memory and power consumption need to be considered as well. Moreover, processors used in mobile devices generally are equipped with a different instruction set. Therefore countermeasures may not be ported easily. Multistack is an effective countermeasure against stack-based buffer overflows. It protects applications by using multiple stacks to separate possible attack targets from possible sources. However, its performance overhead will no longer be negligible on the ARMv7 platform (widely used on mobile devices) and it wastes too much memory, making it too costly for mobile applications. We propose 3 methods to reduce memory overhead up to 28% with only a 3.91% performance overhead.
60330001.pdf (257.55 Ko) Télécharger le fichier
hal-01056081 , version 1 (14-08-2014)
Paternité
Raoul Strackx, Yves Younan, Pieter Philippaerts, Frank Piessens. Efficient and Effective Buffer Overflow Protection on ARM Processors. 4th IFIP WG 11.2 International Workshop on Information Security Theory and Practices: Security and Privacy of Pervasive Systems and Smart Devices (WISTP), Apr 2010, Passau, Germany. pp.1-16, ⟨10.1007/978-3-642-12368-9_1⟩. ⟨hal-01056081⟩
54 Consultations
335 Téléchargements
