Random Number Generation Based on Fingerprints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current research often focuses on the design of new methods that extend the well-established role of biometrics in authentication and identification into key management and cryptography. Methods have been proposed that involve biometric-governed access to cryptographic keys, as well as methods that utilize biometric samples to derive keys for specialized encryption algorithms. The aim of this paper is to present a possible method for random number generation from repeated measurements of fingerprints as an alternative approach to the proposed applications of biometrics in cryptography, and to analyze some of its properties. Such method could provide a valuable source of ranomness in mobile devices equipped with a fingerprint scanner.
60330172.pdf (134.12 Ko) Télécharger le fichier
hal-01056088 , version 1 (14-08-2014)
Paternité
Shkodran Gerguri, Václav Matyáš, Zdeněk Říha, Luděk Smolík. Random Number Generation Based on Fingerprints. 4th IFIP WG 11.2 International Workshop on Information Security Theory and Practices: Security and Privacy of Pervasive Systems and Smart Devices (WISTP), Apr 2010, Passau, Germany. pp.170-182, ⟨10.1007/978-3-642-12368-9_12⟩. ⟨hal-01056088⟩
58 Consultations
320 Téléchargements
