Closed-form approximations of the peak-to-average power ratio distribution for multi-carrier modulation and their applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2014
The theoretical analysis of the peak-to-average power ratio (PAPR) distribution for an orthogonal frequency division multiplexing (OFDM) system, depends on the particular waveform considered in the modulation system. In this paper, we generalize this analysis by considering the generalized waveforms for multi-carrier (GWMC) modulation system based on any family of modulation functions, and we derive a general approximate expression for the cumulative distribution function (CDF) of its PAPR, for both finite and infinite integration time. These equations allow us to directly find the expressions of the PAPR distribution for any particular functions and characterize the behaviour of the PAPR distribution associated with different transmission and observation scenarios. In addition to that, a new approach to formulating the PAPR reduction problem as an optimization problem, is presented in this study.
1687-6180-2014-121.pdf (1.87 Mo) Télécharger le fichier
1687-6180-2014-121.xml (424.38 Ko) Télécharger le fichier
Format : Autre
hal-01056153 , version 1 (16-08-2014)
Marwa Chafii, Jacques Palicot, Rémi Gribonval. Closed-form approximations of the peak-to-average power ratio distribution for multi-carrier modulation and their applications. EURASIP Journal on Advances in Signal Processing, 2014, 2014 (1), pp.121. ⟨10.1186/1687-6180-2014-121⟩. ⟨hal-01056153⟩
383 Consultations
333 Téléchargements
